Activity Forums Apple Final Cut Pro Legacy Sequence settings (field dominance) for DV 25P footage
  • Sequence settings (field dominance) for DV 25P footage
    Posted by Justin Lewis on July 23, 2009 at 2:45 pm
    Aaarrghgh!!!
    I can’t find a definitive answer anywhere on the web – everyone contradicts everyone!
    Ok – Panasonic DVX100a PAL footage shot in 25P.
    Sequence settings – Field dominance: Do I leave set as Lower/Even as if for interlace footage (because even though progressive, DV still records 2 fields), or change it to None – which would be the usual setting for progressive footage from other non-DV sources.
    Someone who KNOWS FOR SURE, please advise – thanks!
    Produce – Shoot – Edit.
    DVX100a. MacBook Pro 2.5Ghz, 4gbRAM. FCS2.
    Rafael Amador replied 17 years, 2 months ago 2 Members · 3 Replies
  • Rafael Amador
    July 23, 2009 at 4:33 pm
    Check the footage as NONE and edit in NONE sequence.
    rafael
    http://www.nagavideo.com
  • Justin Lewis
    July 24, 2009 at 7:40 am
    Thanks Rafael,
    When you say check the footage as none – do you mean in the capture settings? Other than selecting an easy set up for the camera (in this case DVX_Anamorpic PAL – is there something else to check on capture? (in frame rate should it be “all” or 25fps?
    This is separate to the sequence settings where you’re saying select field dominance-none.
    Also – if part of the footage is 50i, will this sequence automatically de-interlace, or is it better to de-interlace that footage first, then import it? I read somewhere it may be better quality doing it that way.
    Thanks again for your help
    Justin
  • Rafael Amador
    July 27, 2009 at 4:40 pm
    [Justin Lewis] “When you say check the footage as none – do you mean in the capture settings? Other than selecting an easy set up for the camera (in this case DVX_Anamorpic PAL – is there something else to check on capture? (in frame rate should it be “all” or 25fps? “
    The footage is captured as Interlaced because although being Progressive have been recorded as Interlaced. Use the s
    Once is in FC you can check it in the Browser as NONE, Upper or Lower First. If your sequence is Progressive, check it as NONE.
    [Justin Lewis] “Also – if part of the footage is 50i, will this sequence automatically de-interlace, or is it bett”
    You can de-interlace the footage in FC, but you better do it with a plugin other than the standard FC de-interlacing filter. Nattress plugins are the best options.
    you can use Compressor or MPGStreamclip as well.
    Cheers,
    Rafael
