Activity Forums Apple Final Cut Pro Legacy Sequence settings + Compression vs. AeCS4
  • Sequence settings + Compression vs. AeCS4
    Posted by Adam Pietraszek on June 21, 2010 at 3:28 pm
    I noticed that when I render gradient-heavy motion graphics in After Effects CS4, next to “output module” it says “Lossless.” When I open and play that rendered .MOV file on any computer, there is NO banding and the quality is superb (1280×720 24p).
    I then import that file into FCP to do my editing.
    Along w/ the AE project, I’m also cutting several 1280×720 24p videos all shot on different cameras (these are already edited and compressed using h.264).
    So I set my Sequence preset to Apple ProRes 4444, 24p, but change the res to 1280×720).
    I do my cutting…
    Send to Compressor and use the Apple ProRes with Alpha (4444, 32bit).
    So…
    This seems to be the ONLY way I can get my final to NOT have gradient banding. HOWEVER, my 3 minute clip is almost 4GIGS! Compared w/ the h.264 version which is only 500gigs.
    Basically I’m asking if there’s anything I can step down in either Compressor or the Sequence presets which will keep the pristine quality (no banding) and reduce the file size?
    Thank you.
    John Fishback replied 16 years, 2 months ago 2 Members · 1 Reply
  • John Fishback
    June 21, 2010 at 4:22 pm
    Have you tried exporting your file to ProRes 422 instead of 4444? It’s 10-bit (as is 4444), but will produce smaller files.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
