Activity Forums Apple Final Cut Pro Legacy sequence settings and frame size
  • sequence settings and frame size
    Posted by Sean Warman on August 9, 2011 at 7:56 pm
    Which sequence setting is appropriate? ProRes 1280×720 or 960×720
    I am working with 4 types of footage:
    DVC Pro 720p60 (59.94 fps, frame size 960×720)
    DVC Pro 720p30 (29.97 fps, frame size 960×720)
    DVC Pro 720p24 (23 fps, frame size 960×720)
    ProRes (59.94 fps, frame size 1280×720 – transcoded from original format h264 cannon footage)
    the primary formats are in DVC PRO 720P60 (40%) and the ProRes (45%)
    I have done several test ProRes sequences in both 1280X720 w/square pixel, and 960×720 w/ hd 960×720 pixel.
    exported through compressor set at HD DVD: H.264 60 Min.
    I am having difficulty seeing the difference. is there one that is better suited for my delivery and better work flow?
    primary release is HD DVD
    there will be a significant amount of slowmo and I will most likely use twixtor.
    thank you for any insight
    Sean
    Imagesandconcepts.com
    Shane Ross replied 15 years, 1 month ago 2 Members · 4 Replies
