Activity › Forums › Apple Final Cut Pro Legacy › sequence settings…
sequence settings…
Posted by Micah Ginn on January 17, 2007 at 5:59 pmif i shoot in 24p, what sequence setting should i use? I’ve always used the DV NTSC 48khz setting (default) on FCP…should i use 24 or 23.98?
thanks,
micahMicah Ginn replied 19 years, 7 months ago 2 Members · 4 Replies -
Shane Ross
January 17, 2007 at 6:08 pmDV/NTSC at 29.97. Only 24PA is 23.98 (24PN in Panasonic HD land).
Shane
Littlefrog Post
http://www.lfhd.net -
Shane Ross
January 17, 2007 at 6:22 pm#23 Differences between 24p and 24pA
Shane’s Stock Answer #23
Quoting Ken Stone’s site found at:
https://www.kenstone.net/fcp_homepage/24p_in_FCP_nattress.html
24p Normal
When shooting in 24p Normal, the camera is adding normal standard 3:2 pulldown to the video, which results in 24p footage designed to work with any non-linear editing suite and it will play back and look good directly to any NTSC monitor. You can use 24p Normal footage just like normal video from any DV camera, and everything will work fine, but obviously, the footage will have a film look to it. If you
