Activity › Forums › Apple Final Cut Pro Legacy › sequence settings…
  • sequence settings…
    Posted by Julienne Rathore on April 18, 2012 at 10:16 am
    dear creative cow,
    a very basic question:
    i am editing a montage made up solely of many stills, all png files.
    the stills are all originally taken from video files (both apple intermediate codec and apple pro res) – what should my sequence settings be?
    thanks in advance!
    julienne
    Julienne Rathore replied 14 years, 5 months ago 2 Members · 4 Replies
  • Chris Tompkins
    April 18, 2012 at 10:36 am
    What is your end destination?
    If it’s DVD (SD) then choose the DV NTSC (if in NTSC land) preset.
    Edit video till done and then,
    Change the sequence settings to 8 bit uncompressed and re-render fully.
    Then Export using Current Settings.
    Drop file into compressor to create the DVD files.
    Chris Tompkins
    Video Atlanta LLC
  • Julienne Rathore
    April 18, 2012 at 11:33 am
    end destination is visual projection mix.
  • Chris Tompkins
    April 18, 2012 at 11:46 am
    So a digital file then? A mov? a WMV? in a powerpoint? mp4?
    If your stills are from a video, then those are your specs, IE:720×480
    See comments above for spec recommendations.
    Chris Tompkins
    Video Atlanta LLC
  • Julienne Rathore
    April 18, 2012 at 12:16 pm
    Maybe I should have been clearer with my details – sorry!:
    the montage contains only stills, all png files.
    the stills are all from video files (apple intermediate codec AND apple pro res).
    the end destionation is a .mov for visual projection.
    i’m not sure if I should set the sequence presets to pro res or apple intermediate (original video is in these 2 formats), or simply hdv?
    (the rest is 1920×1080 and I have chosen 50i since both original video formats are 25fps interlaced).
    julienne
