Activity Forums Apple Final Cut Pro Legacy Sequence Settings
  • Sequence Settings
    Posted by Colleen Fitzgerald on September 13, 2009 at 5:25 am
    I just took a look at all my footage and I have:
    4 different frame sizes: 720×480, 640×360, 720×486 and 720×540
    4 different compressors: DV/DVCPRO-NTSC, Motion JPEG A, Photo – JPEG, Uncompressed 8-bit 4:2:2
    How would you set up your sequence settings?
    -Frame Size?
    -Pixel Aspect Ratio?
    -Field Dominance?
    QT Video Settings?
    The final product needs to be delivered for air on the web at 640×360.
    Thanks for all your help!
    Rafael Amador replied 16 years, 11 months ago 2 Members · 3 Replies
  • Rafael Amador
    September 13, 2009 at 5:45 am
    I would drop everything in a 640×360 Square pixels/ Progressive sequence.
    Proress, and the time base depending of the stuff.
    rafael
    http://www.nagavideo.com
  • Colleen Fitzgerald
    September 13, 2009 at 5:50 am
    I’m def. a novice FCP user … what do you mean by Progressive sequence? How do I make it progressive and what is it exactly.
    I also didn’t understand this part of your answer either …
    I’m sorry I don’t get it. Thanks so much for your help!
  • Rafael Amador
    September 13, 2009 at 6:05 am
    Hi Colleen,
    If you are making a video for a web it must be progressive. So no Upper, no Lower, but NONE as field order. You need to de-interlace the footage you put on it.
    Proress is the codec that I suggest, and about the time-base, if all your footage have the same time base, no problem. If there are different time-bases you need to convert all the footage to a common one.
    rafael
