Activity Forums Apple Final Cut Pro Legacy Sequence Settings
  • Sequence Settings
    Posted by James Doritan on December 2, 2009 at 5:13 pm
    Ok so I’ve captured a video with a capture card, it’s captured at 720 x 480.
    When I drag it in Final Cut I get these awful black bars around the whole video, I’ve tried to change the canvas size in sequence settings but when I do it really messes up the quality of the video, it gets all blurry.
    does anyone know why this is?
    thanks in advance
    Andrew Kimery replied 16 years, 9 months ago 5 Members · 14 Replies
  • 14 Replies
  • Shane Ross
    December 2, 2009 at 5:26 pm
    [James Doritan] “I’ve captured a video with a capture card, it’s captured at 720 x 480”
    To what codec? 720×480? That is DV and DV50 resolution.
    What you need to do is choose and EASY SETUP that matches the format you captured to…create a new sequence, then use that new sequence. IF you had FCP 6 or 7, when you cut the clip into the sequence FCP would ask “would you like to change the sequence settings to match the clip settings?” to which you should click OK.
    Shane
  • James Doritan
    December 2, 2009 at 5:30 pm
    I’ve clicked OK when it asked “would you like to change the sequence settings to match the clip settings” and i’ve still got these black bars around my video, this is so confusing to me, any suggestions?
  • Shane Ross
    December 2, 2009 at 5:50 pm
    Again, what is the format of your footage? When you open the files in Quicktime, do you still see the black bars?
    Shane
  • James Doritan
    December 2, 2009 at 6:41 pm
    This is the info I could find in the “Get Info” window.
    But the problem is it’s been captured it in a weird ratio, and it looks like this in quicktime
    In final cut I’d like to make it 16:9 with a canvas size of 686 x 385, just like this…
    Thanks for all the help, I really appreciate it.
  • Shane Ross
    December 2, 2009 at 6:49 pm
    [James Doritan] “In final cut I’d like to make it 16:9 with a canvas size of 686 x 385, just like this… “
    That isn’t a standard frame size that FCP can deal with without a lot of rendering. Choose the DV/NTSC ANAMORPHIC sequence setting, and check the footage off as ANAMORPHIC and things might look better. But DV is 720×480 always…but if you choose ANAMORPHIC, then it will make it 16:9.
    Shane
  • James Doritan
    December 2, 2009 at 6:56 pm
    I’ve got the settings set as shown.
    This is how the video is being shown in the canvas viewer, see those black bars around the whole video, that’s what I’d like to get rid of. I’d like the video to go to the edge of the canvas, no black bars. Any ideas how to achieve this?
    Thanks again
  • Shane Ross
    December 2, 2009 at 7:13 pm
    Well, I don’t know what that is. Sorry.
    Shane
  • David Roth weiss
    December 2, 2009 at 7:14 pm
    [James Doritan] ” I’d like the video to go to the edge of the canvas, no black bars. Any ideas how to achieve this? “
    Load the clip into the viewer by double-clicking on it, and scale it up a few percentage points. You’re done…
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • James Doritan
    December 2, 2009 at 7:15 pm
    Well that would be at 110% and messes with the quality, any other suggestions?
  • David Roth weiss
    December 2, 2009 at 8:45 pm
    You’re seeing a side by side comparison James, so of course it looks a little softer to you, but no one else will see them side by side.
    David Roth Weiss
    Director/Editor
    Los Angeles
