Activity Forums Apple Final Cut Pro Legacy Sequence setting question
  • Sequence setting question
    Posted by Stewart Charles on May 13, 2009 at 2:19 pm
    Its been suggested that I turn on Render all YUV material in High Precision in my sequence settings.
    Is this something I should do at the start of the project or just at the end when I make the final render? Also I’ve just seen the motion filtering quality option. I have this set to normal is something I should se to best and again do I do this from the start of the project or just at the end? If I select best will this improve the qulity of transitions
    thanks for any help or advise
    http://www.thin-kingmedia.co.uk
    Rafael Amador replied 17 years, 3 months ago 2 Members · 1 Reply
  • Rafael Amador
    May 13, 2009 at 2:23 pm
    Hi Stewart,
    I’ve just responded the question in the other thread.
    Try to keep only one thread or we can get lost.
    Best,
    rafael
    http://www.nagavideo.com
