Activity Forums Apple Final Cut Pro Legacy Sequence setting problems
  • Sequence setting problems
    Posted by Erick Stoll on December 7, 2011 at 5:07 am
    I had an assistant editor organize some interviews for me shot on the ex1 and brought into FCP natively using the calibrated plugin. When I got her project files, her sequence settings are all wrong–the aspect ratio is 1440×1080, and the pixel aspect ratio is too. For the XDCam timeline, the aspect ratio is 1920×1080, and the pixel aspect ratio is Square.
    The problem is, when I copy over the footage in her timeline to mine, the aspect ratio is wrong, with the video squished into a square inside a widescreen frame. Likewise if I try to change her sequence settings to meet mine.
    I hope I explained this clearly enough. Is there any solution to this, or does her work need to be redone?
    Erick Stoll replied 14 years, 9 months ago 3 Members · 3 Replies
  • David Roth weiss
    December 7, 2011 at 5:15 am
    Select all the clips that are distorted, right click, select Remove Attributes, check the Distort checkbox, and hit okay.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    Don’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
    https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1
    Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
  • Rafael Amador
    December 7, 2011 at 6:48 am
    [Erick Stoll] “I had an assistant editor organize some interviews for me shot on the ex1 and brought into FCP natively using the calibrated plugin. When I got her project files, her sequence settings are all wrong the aspect ratio is 1440×1080, and the pixel aspect ratio is too. For the XDCam timeline, the aspect ratio is 1920×1080, and the pixel aspect ratio is Square. “
    They have shoot XDCAM SQ instead of HQ, which means plain HDV (1440×1080 HD pixels).
    Is correct to edit that on a 1920×1080 SQ pixels (Prores better).
    You should set your sequence the same and fallow David advise (Remove attributes> Basic Motion + Distort). The footage will fit in the canvas screen.
    rafael
    http://www.nagavideo.com
  • Erick Stoll
    December 7, 2011 at 1:26 pm
    Thanks! I just might make deadline now!
