Activity Forums Apple Final Cut Pro Legacy sequence setting audio sample rate for music video with canon 5d prores 422
  • sequence setting audio sample rate for music video with canon 5d prores 422
    Posted by Raju Bhai on January 1, 2017 at 6:03 am
    Hello and happy new year!
    The sequence setting for audio defaults to 48khz since canon 5d audio is normally 48khz. However, i am cutting a music video and so i won’t be using any of the video clips’ audio. Instead i have an audio track with the song on it which is a 44khz, 16 bit wav file. Should i convert the song file to 48khz? Of course i’d prefer not to do that as this is an already professionally mastered song at 44khz and i don’t want to degrade the audio at all by up-sampling it. Preferably, i could instead just change the sequence setting from 48khz to 44? When i drop the canon 5d prores clips into my timeline, it only adds the video portion, not the audio, to the timeline, so in this case there’s no reason why i should leave the 48khz default on the sequence setting right? Or is there something i’m overlooking here?
    Nick Meyers replied 9 years, 8 months ago 2 Members · 1 Reply
  • Nick Meyers
    January 1, 2017 at 10:14 am
    video is 48khz, and more oftener than not, it;s 24bit these days
    your final video will be 48k, so convert your audio now, using the “Best” setting in Compressor
    cheers,
    nick
