Activity Forums Apple Final Cut Pro Sequence resize issue….
  • Sequence resize issue….
    Posted by Matthew Angus on July 12, 2012 at 4:54 am
    Hi Guys
    I have a query that is now starting to do my head in, trying to fix ??!!
    I have setup a new compound clip that is 720p. In this clip I will use footage that is 1080p. With this 1080p footage, I also have separate audio from a mike that I want to sync, so I have created a compound clip of this footage & audio together (by right clicking on the 1080p clip and selecting ‘new Compound clip’, with the size to be 1080p.
    However, when I drop this 1080p compound clip into my 720p event timeline, the footage seems to be sized to fit, even though I have selected ‘none’ in ‘spacial footage’ menu.
    This is annoying as I don’t want this 1080p footage on the timeline to appear and behave as 720p, especially when I have to scale up for cutaways, and even with my normal composition size.
    I have attached a diagram to further illustrate what’s happening.
    Cheers
    Matt
    Jacob Lanum replied 14 years, 2 months ago 2 Members · 1 Reply
  • Jacob Lanum
    July 12, 2012 at 3:11 pm
    Same thing just happened to me. You need to select “none” for the clips inside the compound clip as well as the compound clip its self
