Activity Forums Apple Final Cut Pro Legacy sequence renering
  • sequence renering
    Posted by Laurent Dupepe on August 15, 2008 at 5:33 pm
    Is there a way to work in a sequence and not have to render every time a clip is moved? The rendering process is really slowing me down because every slight change in the sequence forces me to render again and again.
    Thank you
    Laurent
    Laurent Dupepe replied 18 years, 1 month ago 3 Members · 6 Replies
  • Tom Wolsky
    August 15, 2008 at 5:39 pm
    Make the sequence settings match the clip settings. What are the clip settings? Check item properties.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Laurent Dupepe
    August 15, 2008 at 6:32 pm
    Thank you Tom. I believe it was a corrupt sequence. All the settings matched.
    I copied the clips in to a new sequence, still had the issue. But when I removed the ‘Basic Motion’ and ‘distort’ video attributes it fixed it.
    What are these attributes? How can removing something I never applied fix this?
    Very grateful for you input.
    Laurent
  • Tom Wolsky
    August 15, 2008 at 6:40 pm
    If those attributes are being changed in the sequence then the sequence settings do not match the clip settings. Check item properties for the clip and for the sequence. What does each say? Please give the details.
    All the best,
    Tom
  • Laurent Dupepe
    August 15, 2008 at 6:54 pm
    They are identical.
    29.97fps
    1280×720
    HDV720p30
    2.4 MB/sec.
    Square
    on both the master clips and the clips in the Sequence.
    I have never fooled with those video attributes that apparently had an effect on one of my Sequences.
    Laurent
  • David Roth weiss
    August 15, 2008 at 7:40 pm
    Lausrent,
    The answer to the riddle will be quite clear to you if take a look at the tutorial which I seem to have neglected to include in my earlier response to your original question.
    https://library.creativecow.net/articles/biscardi_walter/realtime_sequences/video-tutorial.php
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Laurent Dupepe
    August 15, 2008 at 8:11 pm
    Thank you.
    Laurent
