Activity Forums Adobe After Effects Sequence of still composite will not render properly.
  • Sequence of still composite will not render properly.
    Posted by David Johnson on August 13, 2010 at 4:32 pm
    I’ve created a sequence from a composite of still images, but when I render it I experience a lot of dropped frames. I need to edit this file in Final Cut after exporting it, so I wanted to know what format would be best to use, and what I may be doing wrong in the rendering process.
    My current settings are the following:
    Format: Quicktime
    Output: Animation
    Audio: None
    Color: Alpha
    Spatial Quality:100%
    Any help is much appreciated. Thanks.
    – David
    David Johnson replied 16 years ago 60,659 Members · 3 Replies
  • David Johnson
    August 13, 2010 at 4:47 pm
    Yeah, that’s what I thought. Do you know a way we could export this, have it run properly, retain image quality and work on it in Final Cut?
  • David Johnson
    August 13, 2010 at 5:17 pm
    I tried ProRes, but it came out completely white. Could I be doing something wrong? Does it have something to do with the fact that I’m working with JPEGs and not video? I’ll try the other codec.
  • David Johnson
    August 13, 2010 at 6:34 pm
    Figured it out. Just had to change the color mode to RGB. Thanks for the help.
