Sequence “not found” after deleting render files & constant frames
I decided to re-render a sequence because I was getting a “Quicktime error 0” message in the batch monitor when I tried to compress it for DVD. I closed out of Final Cut, deleted render files and constant frames from my scratch disk and emptied the trash. When I re-opened FCP I got a message that the sequence was not found, then an “out of memory” error. I opened my back-up copy of the project with the same results.
I’m running FCP 5.04 on a G-5, OS 10.4.11.
I’ve run Disk Warrior, but it indicates everything’s fine.
Any ideas?
Sharon M.
