Activity › Forums › Adobe Premiere Pro › Sequence Nesting Troubles
  • Sequence Nesting Troubles
    Posted by Brian De herrera-schnering on August 3, 2006 at 6:32 pm
    Am I doing something wrong? I have 3 5-7 minute sequences in a project. I need to make a VHS for client approval. I attempted to nest each sequence into a master sequence so I could play straight through. I loaded the 1st sequence in the source monitor marked my I/O and attempted to cut it in.
    Premiere locked up instantly with a persistant 25% CPU load and varying RAM consumption of 600MB-1.1GB. I rebooted and tried again… same thing.
    I have a very capable system with 2GB of Ram. I don’t think this is operator error. Is there a workaround?
    Brian
    Hector Melendez replied 20 years, 1 month ago 2 Members · 1 Reply
  • Hector Melendez
    August 4, 2006 at 6:35 pm
    Copy & paste should work… but can also down or drag the nested secuence from your project bin into the TL… if I understood you correctly.
