Activity Forums Avid Media Composer Sequence match frame
  • Sequence match frame
    Posted by Matthew Bradshaw on February 4, 2011 at 9:52 pm
    Hi. Coming back to Avid after a while away … I have a clip with 4 audio tracks. I would like to edit the whole clip into a sequence, then add 5 more audio tracks (Music,Sync and mono VO). I would then like to use this 9 audio track sequence as my source. Is there a way that I can link these extra 5 tracks to the video so that when I match frame the video I also get these 5 new tracks? In FCP I would merge them all into a new clip.
    Many thanks, Matt.
    Michael Phillips replied 15 years, 7 months ago 2 Members · 2 Replies
  • Matthew Bradshaw
    February 4, 2011 at 11:10 pm
    Ok … group clips seems to do that, is that the best way?
    Matt.
  • Michael Phillips
    February 5, 2011 at 2:06 am
    If your sequence is only one event and has one video track with any number of audio tracks, select the sequence in the bins and do an AutoSync (bin menu). This will create a subclip to be used as source.
    Michael
    Michael Phillips
