Activity Forums Apple Final Cut Pro Legacy Sequence line missing and linking clips… Please
  • Sequence line missing and linking clips… Please
    Posted by Howard Shooter on March 23, 2011 at 7:10 pm
    I am fairly new to fcp with a couple of probably basic questions. I have been filming about 15 shorts and when I open one specific sequence up the sequence line is missing. Under the window tab it says it’s open but the time line isn’t there.
    Apologies if this is a stupid question… Also…
    Is it possible to link the clips in fcp so I can change the exposure as a grouped set, not always having to do the changes to individual clips?
    Howard
    Jeff Greenberg replied 15 years, 6 months ago 2 Members · 1 Reply
  • Jeff Greenberg
    March 23, 2011 at 9:27 pm
    [Howard Shooter] “I am fairly new to fcp with a couple of probably basic questions. I have been filming about 15 shorts and when I open one specific sequence up the sequence line is missing. Under the window tab it says it’s open but the time line isn’t there.”
    I think the window is closed… – hit CONTROL U (window>arrangement)
    Or…that you’ve scrolled up in the sequence window. Check that too.
    [Howard Shooter] “Is it possible to link the clips in fcp so I can change the exposure as a grouped set, not always having to do the changes to individual clips?
    Fix the first one. Copy. Edit> paste attributes. Make sure your check the filter checkbox.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
