Activity › Forums › Adobe Premiere Pro › Sequence length
  • Sequence length
    Posted by Charles Rudolph on August 8, 2011 at 1:11 am
    Hi all, I have looked and searched around to see if you can set sequence length like in AE. I know you can hit the \ key but im working on a 30 sec tv spot and new to Premiere so I was just wondering if you can…. Thanks
    Charles Rudolph replied 15 years, 1 month ago 3 Members · 5 Replies
  • Vince Becquiot
    August 8, 2011 at 6:00 pm
    Hi Charles,
    Premiere only has work area options.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Charles Rudolph
    August 8, 2011 at 8:20 pm
    So can I trim to work area like AE?
  • Vince Becquiot
    August 8, 2011 at 8:25 pm
    Yes, the work area bar is above the timeline. You can drag it or Use “Alt+[” and “Alt+]” to set in and out work area points to your CTI.
    Vince Becquiot
    Kaptis Studios
  • Jon Barrie
    August 9, 2011 at 4:10 am
    technically what you see happening in AE is the work area comp length makes the full view of the timeline absolute to a set length. That is not how PPro is designed to work.
    Hitting the “\” key (backslash) will zoom out to what is known as the 80/20 view, whereby the edited sequence fills 80% of the timeline panel and the last 20% remains open to add more media to.
    So technically the answer is No it won’t work like AE.
    When you hit backslash key again it remembers the last set zoom in and applies that amount of zoom to wherever the CTI (Current Time Indicator/AKA: Playhead) is placed so a quick zoom out new CTI position and zoom back will give fast responsive workflow with detailed editing along “longer” projects without needing to zoom out out out out, move Playhead, zoom in in in in in.
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Charles Rudolph
    August 9, 2011 at 5:58 am
    Nice follow up. Premier Pro is amazing coming from a FCP user…I feel like I have found a new home
