Activity › Forums › Adobe Premiere Pro › Sequence Length In PP2
  • Sequence Length In PP2
    Posted by Artie K on June 29, 2006 at 3:48 pm
    Is there a way to shorten the total length of my sequence in PP2? I would really like it if I could have a sequence be a total length of 2 minutes, rather than the seemingly infinate length that it is now.
    Artie K
    Steven L. gotz replied 20 years, 3 months ago 3 Members · 3 Replies
  • Mike Velte
    June 29, 2006 at 8:32 pm
    The + and – keys (not on the num pad) can be used to zoom in and out, displaying your 2 minutes across the entire sequence.
  • Artie K
    June 30, 2006 at 1:31 pm
    I think you misunderstood my question. Is there a way to have the length of my entire sequence be only 2 minutes?? Or are we forced to work on a sequence that is extreemly longer than our project needs to be?
  • Steven L. gotz
    June 30, 2006 at 4:41 pm
    There is no way to shorten a sequence like there is in After Effects. But, there is no reason to do so that I can think of.
    If you don’t want to use the rest of the sequence, then don’t.
    Perhaps if you shared your workflow with us, we would understand the issue better, and have a solution that might suit you.
    Steven
    https://www.stevengotz.com
