Activity › Forums › Adobe After Effects › Sequence Layers with script
  • Sequence Layers with script
    Posted by Dan Thomas on May 8, 2013 at 4:12 am
    Through jsx scripting, I would like to select some layers in a comp, and sequence them. Manually, this is done by clicking Animation -> Keyframe Assistant -> Sequence Layers. Is there a way to do this through jsx scripting? Thanks!
    Dan Thomas replied 13 years, 4 months ago 3 Members · 3 Replies
  • Ridley Walker
    May 8, 2013 at 5:16 am
    You might like to look at these 2 scripts:
    https://aescripts.com/sortie/
    https://aescripts.com/rift/
  • John Cuevas
    May 8, 2013 at 1:39 pm
    Videocopilot had a free seequencer script that you can find in the project files of the 103. 3D Ball Dispersion tutorial.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Dan Thomas
    May 9, 2013 at 11:38 pm
    Thanks John, from that I was able to do what I wanted. Here is what I ended up with for anyone else who needs it:
    var frameRate = 30;
    var maxDuration = 10;
    var maxWidth = 760;
    var maxHeight = 500;
    var pixelAspect = 1;
    theComp = app.project.items.addComp(“out_test”, maxWidth, maxHeight, pixelAspect, maxDuration, frameRate);
    var comp_folder = findFolder (findFolder(app.project, “scenes”), “my_folder”)
    comp0 = findItem(comp_folder,”comp0″)
    comp1 = findItem(comp_folder,”comp1″)
    theComp.layers.add(comp0)
    theComp.layers.add(comp1)
    var duration = 0;
    for (var i = 1; i
