Activity Forums Adobe Premiere Pro Sequence In/Out points deleted when using insert/overwrite shortcuts
  • Sequence In/Out points deleted when using insert/overwrite shortcuts
    Posted by Mateo Brooks on February 22, 2018 at 12:55 pm
    Hello, I’m trying to speed up my editing as I work on a live show. Throughout my editing I use an In/Out point on the sequence of a minute and a half which I export from.
    I’ve been trying to switch to using shortcuts instead of dragging, and it works almost perfectly except for importing clips. No matter which option I use on the Fit Clip dialogue box, it deletes the in/out points on my sequence. Is there a way or option I can use to add the clips using the shortcuts without deleting the in/out points on the timeline?
    Here’s an example of what I mean
    Thanks for any help in advance.
    Mateo Brooks replied 8 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
