Activity Forums Adobe After Effects sequence in filmstrip format
  • sequence in filmstrip format
    Posted by S Gregory on May 10, 2006 at 3:23 pm
    I need to paint a 55 frame sequence in photoshop using the filmstrip format rendered from AE.
    I export the .flm sequence from AE with fields.
    I then de-interlace in photoshop to paint frames.(painting on feilds is not an option here)
    is it possible to re-interlace the sequence to get my fields back (as you would in flame )?
    Danny Princz replied 20 years, 3 months ago 2 Members · 1 Reply
  • Danny Princz
    May 10, 2006 at 5:40 pm
    when you “deinterlace in PS” i believe you are throwing away half the frame that you need.
    It sounds like you interlaced footage that you should deinterlace in AE, then take those frames (110 of them) in to PS. then bring them back in to AE
