Activity › Forums › Adobe Premiere Pro › Sequence get cropped when put into another
  • Sequence get cropped when put into another
    Posted by Juan Carlos díaz on August 3, 2014 at 4:54 pm
    I have recorded some talking children footage, each child clip are then put into a sequence so they appear inside and old tv set, this sequence is 1462 wide and 1912 tall.
    After that there’s the main sequence wich is 1920×1980, in this one’s time line is where I’m using the children sequences, moving around the screen, growing, shrinking and bouncing one after another.
    The problem is, that the children sequences are cropped to the 1920×1080 size, and I don’t know what I’m doing bad, if I import a real clip of video that oversizes the sequence size and I resize it down I don’t lose any part of the original image, but when I do the same with those sequences then it happens.
    What can I do to solve this without have to render each of the children sequences as independent videoclips with alpha channel?
    Thanks in advance!! This is my very first post in these nice forums 🙂
    Juan Carlos díaz replied 12 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
