Activity Forums Apple Final Cut Pro Legacy sequence format when dropping HD footage into a DV sequence
  • sequence format when dropping HD footage into a DV sequence
    Posted by Scott Patterson on January 16, 2011 at 6:31 pm
    So I’m taking DVC PRO HD footage and will cut together this project, but the client wants it ultimately full frame 4:3 SD DVD. Thought it would be better to keep the compression on the DV sequence at DVCPRO HD 720p60, but oddly I get red render bars if I do. This can be a big pain since I have a lot of graphics I need to add on the 4:3 sequence. So I tried it with the compression set to DV/DVC Pro and I only the green render bar so I can at least work with the graphics and see what’s going on without rendering every adjustment.
    Will I be losing image quality by using this DV sequence before sending out to DVD Studio Pro? Or is there no difference?
    Thanks for any insight.
    scott
    Scott Patterson replied 15 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
