Activity Forums Apple Final Cut Pro Legacy Sequence error
  • Posted by Andy Hutchinson on May 5, 2005 at 1:37 am
    I have a sequence that I have created that is 4+ minutes long. All the information is in the browser and in the properties for the sequence. Now when I double click it to open it on the timeline I get a message that says “Not Found” and when I click the OK the window says “Error:Out of Memory.”.
    What can be causing this? Is there a way to fix it?
    Andy Hutchinson
    Video Magic
    Winter Park, Fl
    OS-10.3.7, FCP4.5, SP 2.05, Dual 2.5 G5, 2 gigs RAM; Sys HD 200G : WD 200G 7200rpm with 8 Meg buffer; 2 WD 250G 7200 rpm with 8 Meg buffer FW enclosure; Lacie FW800 card; Maxtor 120G FW for storage, 1 WD,
    Andy Hutchinson replied 21 years, 3 months ago 2 Members · 2 Replies
  • Don Greening
    May 5, 2005 at 4:53 am
    Andy,
    Either it’s a corrupt sequence or project file, or the FCP preference files are corrupt. That’s what it sounds like to me, anyway. I would try trashing the preference files first though. Can’t hurt and might just be the fix you’re looking for.
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    – Don
  • Andy Hutchinson
    May 5, 2005 at 5:37 pm
    Thanks Don I will try that. That was the only sequence that has a problem.
    Andy Hutchinson
    Video Magic
    Winter Park, Fl
