Activity › Forums › Avid Media Composer › Sequence disappeared
  • Sequence disappeared
    Posted by Johnny Lamint on March 19, 2011 at 7:42 am
    I’ve been editing for two days and suddenly my sequence is gone.
    I did a mix-down yesterday, began editing and everything has been fine. I enabled audio waveform and MC crashed. I relaunched and the entire sequence was reverted to its original state it was in after the mix-down yesterday. I checked avid attic and the most recent sequence save was days ago even though my auto-save interval is every 15 minutes. Any suggestions?
    win 7 64 Avid MC 5
    Ed Cilley replied 15 years, 6 months ago 2 Members · 1 Reply
  • Ed Cilley
    March 21, 2011 at 5:20 pm
    When you did the mixdown, did you select “Save Premix Sequence”? If so, what bin was selected? Try looking for a sequence in other bins if that is the case.
    Most likely, the autosave did not save between the time you started the audio mixdown and the time you turned on audio waveform.
    Not sure that helps much…
    Ed
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
