Activity › Forums › Apple Final Cut Pro Legacy › Sequence Audio Set To 32 bit
Posted by Andy Lancaster on March 16, 2009 at 10:12 pmWhy does the audio format for my sequences in the bin say 32 bit floating point if my sequence settings are 16bit?
Rafael Amador replied 17 years, 5 months ago 2 Members · 3 Replies -
Rafael Amador
March 17, 2009 at 11:23 amHi Andy;
This “32b floating point” means that the audio will be processed in 32b Floating Point.
This doesn’t presuppose any sampling rate (32Khz, 44,1Khz, 48Khz..) or bit depth (16b, 24b, 32b,..).
Rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Andy Lancaster
March 17, 2009 at 11:37 amThanks. After I posted this, I found where the manual explains it.
As for video…. If I am editing DVCPRO HD, should I be rendering video in 32bit?
Rafael Amador
March 17, 2009 at 12:49 pm[Andy Lancaster] “As for video…. If I am editing DVCPRO HD, should I be rendering video in 32bit?”
I think there are no options about that.
I think is the correct set-up.
If you are dealing with 16/24b signals you need at least 24b processing.
32b FP is much better. Much more precise rendering.
rafael(and here some clips for the friends: https://www.vimeo.com/2694745 )
