Activity Forums Maxon Cinema 4D sequel to graphics machine question
  • sequel to graphics machine question
    Posted by Shanu Shukla on February 28, 2007 at 3:47 am
    hi all,
    i have this same confusion regarding graphics cards…
    is the NVIDIA GeForce series specifically for Gaming PC’s?
    and the NVIDIA Quadro FX for graphics, NLE and 3d Apps?
    I am specifically looking at these two :
    256MB PCIe(TM) X 16 NVIDIA(R) GeForce 7900GS w/TV-out and Dual DVI
    128MB PCIe x 16 NVIDIA Quadro FX 550(D) Dual DVI/VGA
    which one should i choose for graphics, NLE and 3d Apps related work?
    any pointers will be much appreciated!!
    Shanu Shukla replied 19 years, 6 months ago 2 Members · 2 Replies
  • Mylenium
    February 28, 2007 at 7:02 am
    On the base architecture, Quadro and GeForce are the same. The main difference is that Quadros are specially tested, have higher quality RAM, higher bus frequencies for enhanced data rates and some features are enabled that are not available in a standard GeForce, which is both on the board itself and in the driver. So one could say when buying a Quadro, you primarily get better compatibility with pro apps as well as better lifetime guarantee which is simply a matter in which computers those cards end up and how they are distributed. You won’t simply find a Quadro in a gaming machine from a retail shop round your corner, only in high-quality computers from certified partners. In a way it’s a bit of a chicken and a hen question – a good computer is a good base for a powerful graphics card, but a bad computer can not exhaust the potential of even the most powerful one. Both aspects have to be balanced. Since you are an editor and probably will be doing more compositing and editing than 3D animation, a “normal” GeForce should be more than sufficient. Our XPress Pro system runs this way with an older GeForce model and we don’t have any problems. Even 3D animation is not a particular problem on this system, as long as we don’t try to move around a bazillion polygons from a CAD file.
    Mylenium
    [Pour Myl
  • Shanu Shukla
    February 28, 2007 at 8:09 am
    thanks heaps Mylenium!
    Shanu
