Activity Forums Adobe Premiere Pro sequance back from Plural Eyes with different aspect ratio
  • sequance back from Plural Eyes with different aspect ratio
    Posted by Alexandre Brandt on July 29, 2013 at 9:41 am
    Hey folks,
    I have HDV 1080p25 1440 x 1080 (displays at 1920 x 1080) footage in a sequence in Premier.
    I export XML do the sync with Plural Eyes. I import it back but now my sequence displays my image at 1440 x 1080 which makes it squeezed. The render bar is yellow (if that helps you). I tried going in the sequence setting but I can’t change much, things are greyed out. How can I fix that ?
    Thanks.
    motion pictures + storytelling = ?
    -> FILMMAKING !
    Steve Johnson replied 12 years, 9 months ago 2 Members · 1 Reply
  • Steve Johnson
    August 2, 2013 at 7:22 am
    Have you tried creating a sequence with the settings you want then copying and pasting into the new sequence?
    I believe you would still want a 1440×1080 sequence, but you would want to change you pixel aspect ratio to be “HD Anamorphic 1080 (1.333)”
