Activity › Forums › VEGAS Pro › seperating Multicam
  • seperating Multicam
    Posted by Roger Bansemer on May 17, 2011 at 1:37 pm
    I’ve needing to separate my multicam and these instructions by John Rofrano have worked perfectly in the past. However I’ve been trying it for a half hour now and nothing separates. Is Vegas10 working differently than Vegas9 where this is concerned? Here were John’s instructions.
    SEPERATING MULTICAM TRACKS
    After creating multicam you might want to seperate the tracks.
    Here’s how.
    1. Insert a video track right above your multicam timeline.
    Right click on one of the events in your multicam track. Then select “Select in Project Media List”. This will hightlight the file in the “project media” tab. Go there and you’ll see it hightlighted.
    2. Now right click on that file in the project media and click “Select Timeline Events”
    3. Now go back to the timeline but DON’T click on the timeline. Click on the time code area, for instance where it might say 00:13:40. This way your focus will be in the timeline area but it won’t unselect your clips. If you click anywhere else on the timeline it won’t work.
    4. Then with num lock on, hit #8 on your keypad (not on the numbers above your letters). This will move all the clips from your multicam project into the timeline above that you inserted a bit earlier. To bring them back down hit #2.
    That’s it.
    Nigel O’neill replied 15 years, 4 months ago 3 Members · 2 Replies
  • John Rofrano
    May 17, 2011 at 2:36 pm
    [Roger Bansemer] “Is Vegas10 working differently than Vegas9 where this is concerned?”
    Yes, Vegas Pro 10 includes a function to separate the tracks so my instructions aren’t needed. Try:
    Tools | Multicamera | Expand to Multiple Tracks…
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Nigel O’neill
    May 18, 2011 at 3:41 am
    Roger
    Or you could look into Vasst Ultimate S 4.x or Vasst Infiniticam. I use Vasst extensively, not only for its multicam (4 cameras) support, but also for its montage, lower thirds, film looks, MotoFX, audio tools, batch rendering and a range of other nifty features.
    I don’t work for Vasst, in case you were wondering: just know a good tool when I use one!
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
