Activity Forums Adobe After Effects Seperating Color Channels in AE
  • Seperating Color Channels in AE
    Posted by Jason Rouleau on October 3, 2006 at 9:59 pm
    I’m having a brain fart right now and I can’t remember how to simply seperate the color channels for of a video.
    Ex : I want to be able to get my Red, Green and Blue colors of the same video on different layers
    Jason Rouleau replied 19 years, 11 months ago 5 Members · 8 Replies
  • 8 Replies
  • Mark
    October 3, 2006 at 11:40 pm
    You can use set channels and map the channels that you don’t want to see to off.
    Mark
  • Jason Rouleau
    October 4, 2006 at 12:09 am
    Where is the option? I litteraly need 3 layers of the same clip, one red, one blue and one green.
  • Mylenium
    October 4, 2006 at 3:03 am
    Effects —> Channel —> Set Channel/ Shift Channel
    Mylenium
    [Pour Myl
  • Jason Rouleau
    October 4, 2006 at 3:22 am
    basically what I’m trying to do is figure out how to reproduce this here :
    https://www.aviatorvfx.com/index.php?cmd=frontendScreeningPopup&id=color&video=1
  • Jack Hilkewich
    October 4, 2006 at 4:02 pm
    This looks pretty cool. I have gotten as far as the making the matte for the three different channels. At least I think I did it right. I duplicated the three channels that I have made. red, green, and blue. Then I made the bottom ones have a track matte with it set to Luma Matte. Is that Correct?
    Now how does one combine the red and blue to go over the green like they do in the video? And further how do they then combine the the last stage to make the final look? I haven’t delved into this end of After effects before so I am quite in the dark about this.
    Thanks.
  • Tony Kloiber
    October 4, 2006 at 5:09 pm
    Check out this link.
    https://www.pistolerapost.com/tech/2strip.html
    I was thinking about asking Patrick about making this available in Motion so you might see if he would make a plugin that is compatible for both AE and motion.
    TonyTony
  • Jason Rouleau
    October 4, 2006 at 7:09 pm
    Ya, that forum gives you a plugin for FCP, but I want to be able to do it in After Effects.
  • Jason Rouleau
    Thats exactly where I am stuck
