Activity Forums Avid Media Composer Seperate Media Folders within Avid MediaFiles
  • Seperate Media Folders within Avid MediaFiles
    Posted by Don Mick on March 5, 2015 at 5:12 am
    Hello again folks,
    I’m working on some projects with some people but notice that all of their media tends to end up in the ‘1’ folder. I was always taught to give your project a unique media folder number other than 1 or 2, then always copy media into that folder after transcoding/consolidating/importing. That way, all media isn’t in one giant folder, especially if you have several projects on the machine.
    does this methodology still work on avid mc 8?
    Jd Marlow replied 11 years, 5 months ago 5 Members · 4 Replies
  • Shane Ross
    March 5, 2015 at 5:25 am
    Very possible:
    https://lfhd.net/2015/02/10/avid-mc-advanced-tip-organizing-media/
    Note that Any new imports or renders will automatically go into the “1” folder. If you don’t have one, if all of your folders are named, then Avid will make one and put the renders in there.
    Shane
    Little Frog Post
  • Glenn Sakatch
    March 5, 2015 at 3:23 pm
    I still separate all my media. Takes some effort to keep it organized, especially if you switch projects a lot, but makes archiving much easier.
    Glenn
  • Eric Santiago
    March 10, 2015 at 1:59 pm
    Is the 5000 file folder limit still in effect?
    Im not sure when I was told but it was Avid support that put that in my head.
  • Jd Marlow
    March 10, 2015 at 4:55 pm
    One method I’ve employed over the years is to partition my working drive or RAID in order to keep things separated. So if you have a project with footage you shot, graphics, and music or VO, make a partition for each one as you see fit and make sure to import media to the right volume upon ingest. It’s really easy to unmount media later and move it around knowing the right stuff is in the right place.
    Additionally, this makes AMA re-linking easy by just unmounting a volume with your low res media and pointing your sequence to relink to a different volume.
    JD Marlow
    jd@jdmarlow.com
    http://www.jdmarlow.com
