Activity Forums Maxon Cinema 4D Seperate Layers Rendering
  • Seperate Layers Rendering
    Posted by Yevgeni Pey on June 20, 2016 at 10:15 am
    Hello Everybody,
    a bit complicated question. Im making an animated Video in C4D. It has a lot of area shadows and reflections, which means much longer rendering time. The Scene is 2 characters in a living room. As I am Rendering it to PNG sequence in order to open it later in after effects, I wanted to ask if I can render only one Frame of the room (cause it never moves or changes), and later to render the characters seperately. And bring them together in after effects. And if its possible, how would I make the room and the furniture react to the shaddows and light reflections of the charecters?
    Thanks a lot!
    Yevgeny
    Adam Trachtenberg replied 10 years, 2 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    June 20, 2016 at 3:06 pm
    The best you could do, in order to have the shadows and GI from the characters effect the room, would be to strip the room down to a bear minimum to receive the desired effects. So, you could possibly remove the textures, substitute lower-resolution geometry, etc.
