Activity › Forums › Adobe After Effects › Separating Fields
  • Separating Fields
    Posted by Martin Sterling on March 21, 2007 at 11:06 pm
    In most cases, unless Im wrong, doesnt AE separate the fields upon importing your footage. for DV footage, it is usually separating the lower field. When it is not separating fields, You have to manually interpret footage.
    When renderng your file, How do you put the fields back in, and if they’re not in, how does that effect your output. For instance if you take it back into FCP to use with other footage.
    G5 Dual 2.0 GHz processor, OSX.4.8
    Martin Sterling replied 19 years, 6 months ago 14,024 Members · 1 Reply
  • Martin Sterling
    March 22, 2007 at 1:00 am
