Activity Forums Adobe After Effects Separate XYZ and then back
  • Separate XYZ and then back
    Posted by David Biederbeck on August 1, 2012 at 5:31 pm
    I’m on Cs6.
    In the graph editor I’ve separated the xyz values and got my curves just the way I want them. I now want to move on as usual, and not have them separated, but when I click on the separate dimensions button to go back to a single keyframe for position it goes back to linear keyframe.
    Anyone know how to avoid this in the future?
    Obviously I can create a new null to control it. but this is an incredible flaw on Adobe’s part. They could learn a thing or two from Maxon’s graph editor.
    Walter Soyka replied 14 years, 1 month ago 3 Members · 3 Replies
  • Roland R. kahlenberg
    August 2, 2012 at 4:08 am
    You cannot return to normal mode once you’ve applied Separate Dimensions. It’s quite impossible actually and it’s not an Adobe engineering hiccup. Separate Dimensions allows you to create temporal behaviors within the graph editor that are otherwise unavailable/impossible. Reverting to normal mode will inevitably invalidate these unique behaviors.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • David Biederbeck
    August 2, 2012 at 4:21 am
    That’s really a shame. I’m submitting a request at adobe for their next update.
  • Walter Soyka
    August 2, 2012 at 2:15 pm
    [David Biederbeck] “I’m submitting a request at adobe for their next update.”
    I’d suggest you word this one carefully to make sure you get your point across. Someone not familiar with C4D will not necessarily understand the comparison to Maxon’s graph editor.
    From AE’s perspective, you are not asking to move from separated XYZ back to a single position property — you are actually asking to keep all position data as separate properties all the time, with the option to consolidate the separated XYZ properties in the interface under a single expandable position view.
    Walter Soyka
