Activity › Forums › Adobe After Effects Expressions › Separate Text to individual Character layers
Posted by Adam Buritsch on December 19, 2011 at 11:33 pmThis may be more of a scripting question. So forgive me if this is in the wrong place.
Is there a quick way to automate the separating of each letter in a text layer, into their own individual layers? I ask because I have lots and lots of letters that need to be separated and using masks will be plenty time consuming. Plus I’m looking at possible revisions.
Any thoughts would be appreciated!
-AdamLucas Schwartz replied 6 years, 8 months ago 6 Members · 8 Replies -
Dan Ebberts
December 19, 2011 at 11:59 pmI don’t know about quick, but I can think of a couple of possibilities.
I’m assuming that you want each letter-layer to maintain its relative position. You could convert the text to shapes, duplicate the resulting shape layer a bunch of times and eliminate all but one letter from each layer.
Or, you could add an opacity animator that just exposes one character, duplicate the text layer a bunch of times and adjust the animator to expose a different character in each layer.
Both methods could probably be scripted.
Maybe someone will chime in with a better idea.
Dan
Adam Buritsch
December 20, 2011 at 4:01 pmWell, I wasn’t able to use those for what I needed, but your response did get me poking around in the right direction. I’m using a series of Animators to get the effect I was looking for. Thanks for the help!
-Adam
Kevin Camp
December 20, 2011 at 4:17 pmboth would work pretty well…
converting the text to mask and then using this script to make separate layers from each mask might work for you:
https://www.crgreen.com/aescripts/
i do think that the ‘holes’ in letters like O will be put on a separate layer too, so you’d probably need to go back in and correct those… either recombine them with the ‘hole’ as a track matte for the outer portion, or copy/paste the hole mask onto the outer mask layer.
going the character animator route: add an opacity text animator to the text and set it to 0%, then add another opacity text animator (with a separate range selector) and set it to 100%. twirl the ‘advanced’ down for that range selector and set units to index. also set the end to 1 and add an expression like this to the offset:
index-1;
then duplicate the text layer out to build the string — note: the expression assumes that the first layer in the comp will be one of these text layers, if that not the case change the 1 value to layer index of the top most text layer. also, if layers are added above these text layers, the expression will need to be modified, or choose to convert expression to key frames to bake the values.
you could also create your text in illustrator, convert the text to path/outlines there, ungroup them and then, from the little menu in the corner of the layers palette, choose release to layers – sequence. then remove the layers from the parent layer and import the ai file as a comp.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Kevin Camp
December 20, 2011 at 4:17 pmoops, to late….
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Dan Fredley
January 3, 2012 at 12:48 amDon’t know if it’s too late, but here’s a script that separates out characters, words, lines, etc.
https://aescripts.com/decomposetext/
Dan Fredley
Adam Buritsch
January 3, 2012 at 3:05 amNever to late! I come across this a bit so the all replies are quite appreciated.
Lucas Schwartz
December 28, 2019 at 12:08 amToo late? Never. Your ghost is helping me years down the line. Thank you!!!
