Activity Forums Audio Sennheiser MKE 2-1053 to EW100 G2 ?
  • Sennheiser MKE 2-1053 to EW100 G2 ?
    Posted by Jimmy Doyle on November 8, 2010 at 1:39 am
    We just got rid of our Sennheiser EM 1053-U receivers and replaced them with EW100 receivers. We kept the MKE 2-1053 mics and my question is:
    Can we replace the connector with Sennheiser 99112 connectors for the EW100?
    Jimmy Doyle replied 15 years, 10 months ago 2 Members · 4 Replies
  • Eric Toline
    November 8, 2010 at 3:33 am
    No problem. Be sure to use a locking 3.5mm trs plug. The positive goes to the tip and the shield/ground connects to the sleeve. If you have any questions or you don’t feel confident to do the conversion yourself I can do it for you. I also offer guarenteed not to fail G series output cables and G series antenna replacements.
    Eric
    audioetc@bellsouth.net
  • Jimmy Doyle
    November 8, 2010 at 5:20 am
    The MKE 2-1053 has a blue wire, a red wire and an unshielded copper wire. Which wire is negative and which is positive?
  • Eric Toline
    November 8, 2010 at 12:33 pm
    The red is positive. The blue & the copper shield get tied together at the sleeve for ground.
    Eric
  • Jimmy Doyle
    November 8, 2010 at 6:36 pm
    Thanks so much. I’ve got new connectors on the way.
