Activity › Forums › Audio › Sennheiser G3, ME2 Noise..
  • Sennheiser G3, ME2 Noise..
    Posted by Marx Ways on January 9, 2011 at 3:28 pm
    Just got the Sennheiser ew 100 G3, with omnidirectional ME2.
    And now when I done a test with it, I think it got a lot of noise..
    test1: https://www.zshare.net/audio/84967406b0c3f09f/
    test2: https://www.zshare.net/audio/8496762116b4a3b1/
    I have no idea why “test2” got more noise actually..
    Both are set to -18 in “Sensitivity” (transmitter) and -6 in “AF Out” (receiver).
    What setting should I have to get as little noise as possible?
    Use the ME2 sound like this? Does it matter what I record on?
    Would buying a better mic solve the problem, will I get rid of the noise?
    Eric Toline replied 15 years, 8 months ago 2 Members · 3 Replies
  • Eric Toline
    January 9, 2011 at 8:16 pm
    Sounds like the gain was increased somewhere in the chain on sample #2. In any event there isn’t enough self noise to worry about. OTOH the ME 2 that comes with the EW series are basically give away mics. Get yourself a Countryman B3 or EMW for better sound quality.
    Eric
  • Marx Ways
    January 12, 2011 at 2:27 pm
    Is Countryman B better then Sanken cos 11?
  • Eric Toline
    January 13, 2011 at 1:04 am
    The B3 has a similar sound with the added advantage of frequency changing protective caps, more rugged, waterproof & less expensive than a a COS 11. A very good bang for the buck. You can read all about the Countryman line at https://www.countryman.com.
    Eric
