Activity › Forums › Audio › sennheiser g2 100 wireless
  • sennheiser g2 100 wireless
    Posted by Michael Mejido on April 5, 2006 at 1:28 pm
    after looking over everything, i’m strongly considering the sennhesier Evolution G2 100 series:
    https://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=324283&is=REG&addedTroughType=categoryNavigation
    ….however, as usual, i have a few questions.. keeping in mind i’m still quite the newb with all this schtuff..
    1) is it wiser to get a microphone with a transmitter built-in, or is it better to get one of those snap-on transmitters? is there much difference in the quality?
    2) in terms of calibrating/setting up a wireless system, i would be purchasing one on friday evening.. and then would need to use it saturday evening… are they very difficult to set up for a complete newbie like myself?
    3) here’s a *complete* newbie question. Even though right now i’d primarly be doing interviews with a hand-held microphone, i’d like to leave myself open for the possibility of sit down interviews, which of course would be better suited to a pair of lavs. What things do i need to look for to know that a pair of, say, sennheiser seperately bought lavs/transmitters would work with the receiver that i bought with a the wireless microphone? is it just channel sets? for example, if i buy a microphone/reciever with channel set B/626-662 MHz, i would also have to buy lav transmitters with the same channel set? I know this is a complete newbie question 😉
    4) what accessories should i purchase in order to mount a reciever to my dvx100? the sony wireless systems from B&H seem to come with a Shoe-Mount Adapter, but the sennheisers don’t. do any dvx100 owners know what i should purchase?
    thanks everyone 🙂
    Michael Mejido replied 20 years, 5 months ago 2 Members · 2 Replies
  • Will Salley
    April 5, 2006 at 7:27 pm
    Michael,
    I have seen better reception from an all-in-one handheld (mic&transmitter in one housing) than from the Snap-on units, however, the downside is this: If you ever have problems with the mic or transmitter, the other half of it becomes useless. I think that since the transmitter is built into the mic it has a better antenna position. The plug-on units have to use a less-than-ideal antenna postion. The sound quality is generally identical between the two types.
    You should be able to setup your system and TEST it within a few minutes. A few pointers:
    – Always use fresh batteries at the start of the day. Remove the used bats form the unit at the end of the day. I save my used batteries for other, less critical uses.
    – Turn the system on and walk around and use it for a few hours. Make sure that no intermittent interference occurs on the channel(s) you intend to use. Doing this will also warm-up the system and check against faulty manufacturing.
    – Keep the receiver away from large metal objects and high-voltage sources. This includes cables.
    – Set levels and such from the camera backwards. In other words, set the camera inputs for standard “line levels”, which in the case of the DVX100, are +4db. Adjust the input GAIN on the camera to unity. This will be a indicated by a “U” or sometimes it’s at “7” – check the manual. Then adjust the level of the transmitter to indicate proper levels on the camera meters. This way, when you switch out the wireless for a wired mic, or just change mics, you will have a standard setting in which to reproduce later.
    -Wireless systems are assigned ‘frequency blocks’ (the”B-block you referred to). Purchase the best frequency block for your area. See the link below.
    https://www.sennheiserusa.com/newsite/mat_dev/frequencyfinder/Freqfinder-ew.asp
    Always buy additional receivers and transmitters in that block and you should have no problems.
    – The DVX100 is so small that it’s hard mount a receiver, but you can buy mounts for most models that can be attached to the hot-shoe or battery. Try TAI Audio or Location Sound.
    https://www.taiaudio.com/catalog/index.php
    https://www.locationsound.com/proaudio/ls/index.html
  • Michael Mejido
    April 7, 2006 at 6:44 pm
    again, thank you very much for sharing your knowledge 🙂
