Activity Forums Audio Sennheiser Ew100 Em100
  • Sennheiser Ew100 Em100
    Posted by James Sornig on January 27, 2011 at 10:33 pm
    Hello,
    I have a Sennheiser EM100 receiver and a EW100 transmitter. This system works great for our church. Recently I was asked to get a second transmitter, so I bought another EW100 from ebay. I assumed that I could have both transmitters on at the same time, but I have not been successful in getting it to work. Well, sometimes one transmitter will be on and then the other will work. If I turn one of them off then everything works fine. Both transmitters work but not at the same time. Is there a special setting or do I need to get another receiver? Thanks for any help.
    Jim
    Ty Ford replied 15 years, 6 months ago 4 Members · 5 Replies
  • Eric Toline
    January 28, 2011 at 3:32 am
    Your problem is that both transmitters are on the same frequency. You can have one transmitter feeding many receivers (like television or radio does)but not the other way around. You’ll need to get another receiver in the same frequency block. Then you will need to tune each set to different frequencys within the block.
    Eric
  • Peter Groom
    January 28, 2011 at 1:53 pm
    AND to lessen the chance of problems, make sure you get another receiver from the same manufacturer / product range (if youre picking one up off ebay.) There is nothing to say that a different manufacturers frequency will be able to pick your sennheiser even though the freq may be the same!
    Peter
    Peter
  • Ty Ford
    January 28, 2011 at 4:54 pm
    Hello James and welcome to the Cow Audio Forum.
    What were you trying to do with two transmitters and one receiver?
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field GuideWatch Ty play guitar
  • James Sornig
    January 29, 2011 at 12:28 am
    Hello Ty,
    We want to have both transmitters working during our church service. I was hoping I only needed on reciever and both transmitters would be able to connect to it at the same time. Oh well, I will just buy another receiver.
    Jim
  • Ty Ford
    January 29, 2011 at 12:33 am
    You are correct, sir! 🙂
