Activity Forums Adobe Premiere Pro Sending to Media Encoder
  • Sending to Media Encoder
    Posted by Barry Ford on April 4, 2013 at 9:21 pm
    Hello!
    I have 6 projects with roughly 50 sequences each that all need to be sent to Media Encoder. Does anyone know if I can send all the sequences in a project at once to Media Encoder? I have been doing this 1 sequence at a time and would like to find a way to speed up the monotony of this process!
    Kevin Monahan replied 13 years, 4 months ago 5 Members · 6 Replies
  • Chris Tompkins
    April 4, 2013 at 9:59 pm
    Send em to AME via Queue.
    When all is in queue and ready to encode, let er rip.
    Chris
  • Chris Borjis
    April 4, 2013 at 10:16 pm
    This has worked for me as well, but sometimes the files
    rendered out have problems. Glitches or shorter than they should be.
    Make sure you spot check them before sending.
    Another option is to open media encoder and drop the project
    file in the que, it should ask which sequences to encode.
  • Barry Ford
    April 4, 2013 at 10:37 pm
    That did the trick, thanks Chris Borjis, and I will double check them after they encode, I have also had a few issues with encodes being shorter than should have been!
  • Kevin Monahan
    April 4, 2013 at 11:07 pm
    Good suggestions. You could also use a watch folder to drag and drop items into.
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Tim Kolb
    April 4, 2013 at 11:11 pm
    [Kevin Monahan] “Good suggestions. You could also use a watch folder to drag and drop items into.”
    Clips, yes…project files don’t work this way unfortunately.
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Kevin Monahan
    April 4, 2013 at 11:36 pm
    Ah, right. These other suggestions are just fine. Thanks Tim.
    Kevin Monahan
    Social Support Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
