Activity › Forums › DaVinci Resolve › sending fixes to a select group of shots.
  • sending fixes to a select group of shots.
    Posted by Rick Turners on April 4, 2011 at 7:37 pm
    I’ve done a grade on an entire scene, client asks to desaturate the scene overall by 10%. Cant do this in the track, because it’ll desat everything.
    Is there a way, like in Color, to do a Primary Out and drag that to the selected group of shots?
    Or do I have to goto each shot and add a node?
    Rick Turners replied 15 years, 5 months ago 3 Members · 3 Replies
  • Michael Cinquin
    April 4, 2011 at 8:28 pm
    what I do is make a group of them, then do the adjustment.
    Problem is when I want to make an individual ajdustment, I have to take the clip off the group first.
    Michael Cinquin
    Final Cut Pro – Avid Media Composer editor
    DaVinci – Color – Baselight colorist
    Color profiles for Color
    http://www.michaelcinquin.com/tools : tools for FCP | Color | RED | subtitles | Cinema Tools | Timecode – Keycode calculator
  • Chris Hall
    April 4, 2011 at 9:19 pm
    you could just use track marks, I’ve done this is in the past. Add a few nodes (to make changes later if you want) Mark the beginning of the scene, mark the end, then apply your desat. Done. Won’t affect anything before or after the marks.
    Chris Hall
    Colorist – Basher Films
    Pasadena, CA
  • Rick Turners
    April 6, 2011 at 4:43 pm
    Any other suggestions? Would be nice if I could just drag an append node to the desired shots?
    So in Track, I have to add an In and Out point, create a node in Track, and it will only effect those within?
    What about multiple in and outs for multiple semi global changes?
