Activity Forums Adobe After Effects Send video/comp to sub-comp layers dynamically?
  • Send video/comp to sub-comp layers dynamically?
    Posted by Lyle Hirsch on February 3, 2016 at 3:02 am
    Is it possible to feed one layer into another dynamically? In other words, I’ve made a template composition where a video has been cut into two layer halves. Those two halves are key-framed with a slider to pull apart or come together as a transition to reveal the scene behind it. I’d like to be able to dynamically change the two layer halves to whatever scene I need to be transitioning out from.
    I know I could use TrkMt to mask, but then the layers don’t move, they just mask away. I need the video to be sent to the sub-comp’s two layers so it can be torn apart. Is this possible, or am I going to be stuck doing this effect by hand over and over again for each transition?
    Thanks.
    Lyle Hirsch replied 10 years, 7 months ago 2 Members · 4 Replies
  • Chris Evans
    February 3, 2016 at 4:04 pm
    I’m not exactly sure what you’re asking. It sounds like you could use a pre-comp, but then you use the term sub-comp and I don’t understand what your describing? You want to feed a comp into itself?
  • Lyle Hirsch
    February 3, 2016 at 5:16 pm
    I’ve created a pre-comp were a video has been split into two layers, and masked into halves. Those halves are animated to split apart, and slide off screen to reveal a new scene behind it. (Video cuts in half, and flies apart to transition scenes)
    Right now, that pre-comp, obviously, always plays the same video clip, seeing as that’s what I manually set up in its timeline. My hope is that I can somehow make those video clips variables, or something, that I can swap out dynamically without having to manually create a unique pre-comp for each individual transition with static video layers defined in each comp for each transition.
    My hope was that I would be able to make the effect once, and re-use it multiple times without having to manually create each unique transition clip, or maintain dozens of different unique transition comps for this project.
  • Lyle Hirsch
    February 3, 2016 at 7:44 pm
    Thanks, Dave.
    That idea sounds like what I was originally tinkering with, but I was finding that with all of the cuts I needed to do (literally, hundreds) it was making the project really unwieldy. But, it’s likely I’m just confused.
    If I understand your suggestion, replacing the video in the composition would still require me to maintain individual pre-comps with different videos set for the two halves, no? If this is wrong, could you please elaborate?
    Thanks again.
  • Lyle Hirsch
    February 4, 2016 at 8:29 am
    I absolutely agree with you about it getting old fast, but it’s an effect the client has pretty much insisted on. It’s being matched up with a beat to produce a slide show of sorts, and they want these scenes cutting at different angles, and flying apart throughout this looping clip.
    That said, it sounds like I was on the right track with my original ideas, and that I’m just gonna have to strap in for some tedious busy work.
    Thanks for the help, Dave. Appreciate it!
