Activity Forums Square Box CatDV Send to fcpx problem
  • Send to fcpx problem
    Posted by Henrik Helms on May 22, 2015 at 3:54 pm
    Hi!
    I am on CatDV 11.03 and when I import files from Canon C300 into Catdv and can see it display two audio tracks in catv client – but when I use send to fcpx (fcpx 10.2.1) – the clips comes up fine – but is only say it has a mono track. Why is that – and what can I do to change that so it brings in both audio channels?
    Greetings
    Henrik Helms
    dBA MEDIA
    Dougal Matthews replied 11 years, 2 months ago 2 Members · 5 Replies
  • Henrik Helms
    May 22, 2015 at 7:03 pm
    I updated my client – but the problems with sending mxf files to fcpx remains – it still imports it as an mono file – not two channels – but only one.
    Greetings
    Henrik Helms
    dBA MEDIA
  • Henrik Helms
    May 31, 2015 at 5:07 pm
    The latest update .06 did the trick – the bug has dissappeared and now the send to fcpx functions properly with audio
    Greetings
    Henrik Helms
    dBA MEDIA
  • Dougal Matthews
    June 2, 2015 at 11:02 am
    hi Henrik
    I’m glad the latest update fixed your issue thank you for letting us know
    cheers dougal
    Improvise Adapt and Overcome
  • Henrik Helms
    June 12, 2015 at 9:09 am
    Well after further testing – it turns out it does not work. If we send two tracks video imported to CatDV from a CF card (from our C300) the problem still exists – it only bring in one channel audio.
    Greetings
    Henrik Helms
    dBA MEDIA
  • Dougal Matthews
    June 15, 2015 at 3:28 pm
    hi Henrik
    I’m sorry to hear you are still having issues
    please could you do the following
    restart catdv
    create a small catalog with a few clips
    export the clips as an FCP xml file
    save the catalog as a local *.cdv file ( File menu > local catalogs > save as catalog )
    could you then email support@squarebox.com with :
    the catalog
    the xml
    the catdv logs
    a brief explanation of the issues you are having
    see our guide here on exporting logs https://www.squarebox.com/exporting-logs-to-support/
    thank you dougal
