Activity › Forums › Apple Final Cut Pro › Send to compressor
  • Send to compressor
    Posted by Matthew Celia on August 24, 2011 at 8:42 pm
    I’m having some problems sending to compressor from Final Cut X
    Brand new iMac 3.4ghz i7 – so it’s very clean. Compressor is installed.
    When I select “Send to Compressor” nothing happens.
    When I select “Export using Compressor Presets” I hear an error sound (no dialog pops up) and basically all the menus are greyed out. I have to force quit the program to continue using it.
    Just curious if any one else has had issues and if there were any fixes.
    Thanks in advance!
    FCP Guru
    http://www.fcpguru.com
    Jeremy Garchow replied 15 years, 1 month ago 3 Members · 5 Replies
  • Jeremy Garchow
    August 24, 2011 at 9:23 pm
    Send to compressor doesn’t work for me either.
    Using coompressor presets does. Did you by chance load in a bunch of custom settings from your old compressor?
  • Mark Morache
    August 25, 2011 at 1:10 am
    It worked for me. It’s a bit slow, but it allows me to select an in and out point for transcoding.
    Compressor opened right up… actually not right up. It was a little slow.
    There’s no setting for my Elgato Turbo, so h264 is pretty slow. I’ll probably still render out a quicktime movie to use for encoding.
    Oh where is my lovely QT reference option? I miss it terribly.
    I’m calling it FCX. They took the “pro” out, so I will too.
    I’ll reconsider after the first upgrade.
    Mark Morache
    Avid/Xpri/FCP7/FCX
    Evening Magazine,Seattle, WA
    blogging at https://fcpx.wordpress.com
  • Matthew Celia
    August 26, 2011 at 6:08 am
    Nope, brand new machine. Nothing on it. I’ll keep tinkering and see what I find. Hoping someone has a solution…
    FCP Guru
  • Matthew Celia
    August 26, 2011 at 6:22 am
    Here is what the console says when I click on “Send to Compressor”
    FCP Guru
  • Jeremy Garchow
    August 26, 2011 at 1:29 pm
    No picture
