Activity Forums Apple Final Cut Pro Send to Compressor crashes
  • Send to Compressor crashes
    Posted by Chris Torella on May 28, 2014 at 2:47 pm
    so i FCPX seems to crash any time i send to compressor
    i have a feeling my destinations layout might be the problem – can i trash that ? and where can i find it?
    i’ve look inside the fcp bundle but dont see any likely candidates?
    thanks
    Chris Torella
    Pickerel Pie Entertainment
    10-26A 46th. Ave.
    Long Island City, NY, 11101
    718.606.9840 O
    718.606.9843 F
    Jerome Raim replied 12 years, 3 months ago 2 Members · 1 Reply
  • Jerome Raim
    May 29, 2014 at 10:35 pm
    No good reason to “Send to compressor”. It’s the slowest exporting method. Your best bet is to create the desired preset in Compressor and then add it to your “Shared destination” in FCP X. You can then export from FCP X directly.
    Anyway, Digital Rebellion’s Compressor Repair usually does the trick to fix Compressor-related issues (works with 4.1.1):
    https://www.digitalrebellion.com/compressorrepair/
    If it doesn’t, the culprit should be somewhere in /YourUser/Library/Application Support/Compressor. You can delete everything in that folder and empty your trash (all settings and destinations will be lost).
    Jerome Raim
    Post-Production
    JeromeRaim.com
