Activity Forums Apple Final Cut Pro Legacy Send multiple timelines to Compressor???
  • Send multiple timelines to Compressor???
    Posted by Michael Garske on April 5, 2010 at 8:40 pm
    I have several timelines which I would like to send to compressor simultaneously with the same compression settings.
    Is there a way to submit all of the timelines to Compressor from Final Cut at the same time?
    I know there must be a simple answer, I’ve just never attempted it before. Thanks ahead of time for your input.
    Michael Garske
    Stand Apart Productions
    https://www.youtube.com/user/Garrrske
    Chris Borjis replied 16 years, 5 months ago 4 Members · 5 Replies
  • Zane Barker
    April 5, 2010 at 8:54 pm
    Export reference movies and then open compressor and bring in the reference movies.
    Hindsight is always 1080p
  • Michael Garske
    April 5, 2010 at 9:55 pm
    How do you make a reference movie? Does it have to render that out to make a QT file?
  • Michael Garske
    April 5, 2010 at 10:14 pm
    Do you mean export-quicktime movie? Is that generic export considered a reference movie? If that’s the case it would take a lot of added time to export in that way as well as using compressor.
    Ideally what I’d like to be able to do is set all them in a list to render over night so I wouldn’t need to baby sit each export.
  • Steve Eisen
    April 5, 2010 at 10:33 pm
    If you take a look at FCP’s manual (Help Menu) you will learn about batch export. It also explains what a reference movie is.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Chris Borjis
    April 5, 2010 at 10:43 pm
    select the sequences then right click batch export and set the destiny
    and codec and what not, then let the machine do its thing.
    the run them through compressor with clustering turned on.
    Rendered timelines export pretty fast I’ve found.
