Activity Forums Zaxwerks Self-shadow in Serpentine?
  • Self-shadow in Serpentine?
    Posted by Shawn Marshall on May 5, 2010 at 11:27 pm
    Hi:
    I can’t tell from the manual whether I should be able to successfully have different Serpent elements cast shadows upon each other in a single iteration of Serpentine.
    I have a layer with Serpentine applied and five different solids creating paths to generate five ribbons. I have a spotlight and camera in the scene. If I make the light cast shadows I sort of get some ribbons casting shadows on others, but there are some artifacts, even with the shadow quality cranked up to 4000. The artifacts become more apparent as I increase the shadow diffusion on the spotlight. You can see these artifacts running perpendicular to the ribbons in this image:
    Here’s the same image with “Casts Shadows” turned off on the spotlight:
    The spotlight is at least 2000 pixels away from the path objects. To be clear, I’m not attempting to make these ribbons cast shadows onto another layer. I want accurate shadows generated within this single iteration of Serpentine on one layer.
    Any thoughts?
    Thanks.
    Shawn Marshall
    Marshall Arts Motion Graphics
    Edward Wu replied 16 years, 4 months ago 2 Members · 1 Reply
  • Edward Wu
    May 6, 2010 at 7:34 pm
    Hi Shawn,
    Thanks for the detailed post. I looked into this and it looks like you may be running into a bug with spot lights casting shadows. We’ve fixed this issue now so if you send me an e-mail, I can send you an updated version of the software.
    Please contact me at ed@zaxwerks.com
    Best,
    Edward
