Self -Resizing Text Background
Hi everyone!
I’m stuck with doing what at first glance can seem an easy thing. I want to do these self-resizing text backgrounds and animate them like it’s done in this template (starting from the 00:02).
You see, these plain rectangles behind text. I would ise sourceRectAtTime(), but it is not working with left- or right-aligned text. So I used the technique from Mikey’s tutorialinvolving box blur and curves. It’s actually a great and simple way to make a plain text background:
https://www.youtube.com/watch?v=bD5xw9m-sc4However, I have troubles with animating this text. If I animate text opacity, the letters appear, but the text background stays the same despite of any text animation.
May be I could use someone’s piece of advise to overcome this problem, please? Or you know another way for making these text backgrounds that resize themselves along with the text?
Thank you!
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
