Activity Forums Adobe After Effects Expressions self referencing valueAtTime Problem
  • self referencing valueAtTime Problem
    Posted by Ludwig Tomaschko on July 28, 2018 at 1:01 pm
    Hi!
    I have an object and its scale is driven by expressions.
    i have the scale value at second 4 ———— .valueAtTime(4),
    then I’m doing some calculations with it and i’m adding it to itself at second 6.
    because the expression is influencing the scale at second 4 too, AE is making trouble.
    is there a way to say AE: don’t affect values in the past?
    thanks in advance!
    Ludwig Tomaschko replied 8 years, 1 month ago 2 Members · 2 Replies
  • Andreas Brand
    July 28, 2018 at 2:36 pm
    Hello Ludwig
    I’m not pretty sure if I understand you right.
    I think you can’t reference with the same expression to the valueAtTime from another second. Because AE reads the expression every frame new.
    I would do it like this:
    if(time>=6){
    //var scale4seconds = calculations which should affect only the scale before second six
    // scale4seconds + newCalculations
    }else{
    // do the calculations which should only affect the scale before second 6
  • Ludwig Tomaschko
    July 28, 2018 at 7:56 pm
    Hi Andreas!
    I can not test it right now, but i think this will make it.
    It didn’t come to mind to put in in an if/else statement.
    I’ll give it a try when I’m on the computer,
    THANK YOU!!!
